01-21-2013 07:47 PM - last edited on 03-05-2024 01:56 AM by ROGBot
01-21-2013 08:00 PM
01-21-2013 08:02 PM
01-21-2013 09:17 PM
01-22-2013 03:27 AM
01-22-2013 07:45 AM
05-27-2015 09:08 AM
05-01-2023 10:49 PM
Check the voltage readings on other sensors: Check if other sensors are also showing high voltage spikes. If they are, then it could be a problem with the power supply or the motherboard.
Check for loose connections: Make sure all connections to the motherboard are secure and tight. Loose connections can cause voltage spikes.
Check for dust and debris: Dust and debris can cause electrical shorts and spikes. Check for any buildup on the motherboard and clean it with compressed air.
Check for damaged components: Look for any damaged or burned-out components on the motherboard. If you find any, then it is likely that the motherboard needs to be replaced.
Update BIOS and drivers: Check for any BIOS or driver updates for your motherboard. Sometimes, outdated BIOS or drivers can cause voltage spikes.
Check with the manufacturer: If none of the above steps work, then it is best to contact the manufacturer of your motherboard or CPU. They may be able to provide more specific troubleshooting steps or recommend a repair or replacement.
It is important to address any issues with high voltage spikes as they can damage your components and potentially cause a fire hazard.
