12-12-2012 10:40 AM - last edited on 03-06-2024 06:33 PM by ROGBot
12-12-2012 11:11 AM
12-12-2012 12:29 PM
12-12-2012 04:18 PM
12-12-2012 04:43 PM
najirion wrote:
I was using this PSU (Corsair TX650) for 10 months now. I don't remember it being like this. 😞 So it's the PSU? I think somethings is wrong with it. This was just recent... I am getting screen freezes from time to time too
12-12-2012 04:55 PM
12-13-2012 02:58 AM
12-13-2012 10:15 AM
najirion wrote:
I had it checked, they spent the entire day checking everything and found that it was the motherboard 😞
It was like the motherboard had a stroke, some of the headers aren't working and wasn't supplying enough power to the processor says the dealer's technician.
Anyway, It was still 6 months old, it was sent for RMA now.
12-13-2012 10:11 PM
cl-scott wrote:
Well, the important thing is that you found what the issue was. I'm honestly a little surprised the unit would boot and run at all with just a bit over half the voltage it was expecting. Anyway, it might not be a bad idea to kind of stress test other components, like PCIe cards and RAM, when you get your replacement. Anything that would have been drawing power from the main 12V rail you will want to check. Hopefully everything comes out fine, but it's possible there's some collateral damage.
12-14-2012 04:21 PM
najirion wrote:
Thanks for the advise. 🙂 Yep will do that. This was all of a sudden. Did OC my i5-2500k to 4.0Ghz with it and it was running fine. Even ran prime95 for 2 hours. Didn't restart or BSOD whatsoever.. wonder what happened to it.. 😞
