(HELP) Crosshair V Formula Z Memory Issues
Kaill
So i have the crosshair V formula Z board im running Patriot PXD38G2400C11K(XMP) 8GB ( 2x 4GB ) they are both in the red slots i have the most current bios 1101 but for some reason the system thinks my ram is only 800 instead of 2400
specs
Processor AMD FX-8350
grahics EVGA gtx570 SC
8 gigs of the PXD38G2400C11K(XMP)
running windows 7 enterprise 64 bit
current bios 1101
please help i currently have the ram in bios set to the 2400 oc but it only runs it at 1200.
10 REPLIES 10
yes and it will only go to 1200 i can't even get it to 1600 😞15687
sectionate
Level 12
looks fine
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
Myk_SilentShado
Level 15
Reading 1200 is perfectly fine, CPU-Z only reads one side of your Double Date Rate RAM...hence only 1200 🙂
ok this is asus pc diagnostics and its reading it at 800 for some reason 15692
Myk_SilentShado
Level 15
Is that a Windows program? if so, i'd say it's the same again, only reading half of your RAM's speed
Granger
Your CPUZ screenie says its running at 2408Mhz
The Asus screenie says 1600Mhz, but maybe that is only reading base capacity? My rig does the same, I have PC3-17000 that is recognized as PC3-12800 although I run it faster (can't get the damn 2133 with it though 😞 )
HiVizMan
Level 40
Your ram is running at over 2400MHz dude what more could anyone possibly want. There are folks here on this forum that would give an arm for 2400MHz on their AMD boards
Kaill
first time using cpu-Z didn't know it did that.
