[HELP] Asus Rampage IV Extreme. USB still ON after shut down
Sofyan88
Hi guys.
I'm just purchase an ASUS Rampage IV Extreme.
I Have some question here.
USB power still ON, even when computer is shut down.
may be someone tell me this: "why don't you just cut off the PSU switch button? or directly cut off the head power outlet?"
I DO. but it's still very annoying. come on, this is an era of instant right. this not an era of IBM PC pentium I, pentium II, pentium III or some other old stuff.
I know this is may be the smart feature to charge your mobile device like iPhone or iPod, even when the computer is OFF. but this is really annoying for me, cause I have so many USB Devices like external HDD, USB Modem, external USB fan. etc. and It's not funny to see my USB Devices still working (ON) even the computer is OFF.
at least tell me how to turn off that feature?
I've see the FAQ on ASUS website, and not found anything about my problem.
I've already update the latest BIOS, but still same problem.
I've try to setting all feature on the ACPI Configuration. disable all setting like power on keyboard, power on mouse etc. and still nothing.
can anyone help me?
I hope it's any ASUS guy here where can explain this problem,
at least tell me how to turn off the USB power when the system is off?
Please help me, if any way to solve this preblem.
Thanks in Advance.
Update: 06-03-2012
Today, I'm try the PSU with ErP/EuP support as Raja@ASUS Recommendation. have to Enabled ErP option on BIOS
and the problem still same. USB Power still ON, even the Computer is Shutdown
I'm using the Seasonic P860. Platinum
so, the problem is not solved... yet.
anyone have same issues with me?
32 REPLIES 32
chrsplmr
Level 18
Raja .. when you are done with your other piles .. start on this one.
(btw..your check is on the bottom .. that Asus .. such a sense of humor.)
8302
..or was it this one ? hahaha .. honest, it's should be here somewhere.
8303
Raja++ .. always ..
Great thread, thank you all. (Look Ma, Im accidently Learning.).c.
Sofyan88
Update: 06-03-2012
Sofyan88 wrote:
Update: 06-03-2012
Depends how the PSU handles ErP. Up to 1W of power from AC can be supplied in tolerance of ErP spec. Corsair AX range switches off 5VSB with ErP, never tried Seasonic.
dubez
Hello! I am new on this forum but, i have same problem. I just build my new system:
PC Specs:
Motherboard: Asus Rampage IV Extreme
GPU: SLI 2x Asus GTX 680 DirectCU II TOP @ 1201 Mhz
CPU: i7 3930k 6 core @ 4,3 GHz
CPU Cooling: Corsair H100i
Case: Nzxt Phantom 820
Memory: 4 x 4GB Corsair Vengeance 1866Mhz CL9 Red
SSD: Ocz 128Gb SSD (boot)
HDD: 2x 1TB 7200rpm
Soundcard: Asus Xonar Phoebus
PSU: OCZ ZX Series 1250w 80+ Gold, Full Modular
Dvd: Asus DRW 24B5ST
Lamptron FC6 Fan controller
I have CM Storm Sirus headset and after i shutdown my pc, my headset lights are still on. I have tried with erp enabled and disabled... i have to everytime switch off my psu after shutdown... this is making me crazy. really! I need help too. My mouse and keyboard goes off an all other lights but, my headsetlights are still on and i have tried with all usb ports and dosent make any difference. Please help!
Nodens
Level 16
Your particular PSU does not switch off the USB power with ErP so there is nothing you can do about it. If it bothers you that much buy another PSU that does.
RAMPAGE Windows 8/7 UEFI Installation Guide - Patched OROM for TRIM in RAID - Patched UEFI GOP Updater Tool - ASUS OEM License Restorer
There are 10 types of people in the world. Those who understand binary and those who don't!
RealBench Developer.
izajasz
I had my Razer Black Widow occasionally stay light up after shutdwon, thats how ive found this, but ERP is not that ideal when overcloked. For me it cold boots twice if multi set higher than 43x ; (
MOBO: MVIE BIOS 1402 stock
CPU Core i7 4770K
RAM: 16GB Corsair Dom. Platinum CMD16GX3M4A1866C9 in XMP, SPEC: http://bit.ly/Z56xfm
SSD/HDD: OS-SAMS 840Pro 256GB, APPS - SAMS 830 512GB, DATA - Seagate ST1000DM003
GPU: 2x EVGA GTX 680 FTW+ in SLI config (UEFI BIOS)
AUDIO: Onboard
CPU Cooling: Corsair H110
PSU: Seasonic Platinum 1000W (SS-1000XP)
CASE: NZXT Phantom 630
DISPLAY: ASUS VG278Q (120Hz)
See answer on your thread on why that happens:)
i have the same probleme anybody find the problem ?????
Raja
Problem is how PSU support ErP. If your PSU supports it like Corsair AX1200, then enable ErP in APM section of UEFI to turn off 5VSB to USB.
ok if i understand if my psu dont support the erp mode my usb still on after shuntdown
i have a antec tpq-1200 and with the erp enable or not my usb is on
