Motherboard model: ASUS H170 PRO Gaming
UEFI Version: 0703
CPU: Intel Core i5 6600
Memory kit part number (s) and amount in GB: 2 x 4GB HyperX Fury Black
GPU: none - iGPU
SSD/HDDs/Optical drives: 1 x Samsung Evo 850 120GB, 1 x Western Digital 1TB
PSU: EVGA 600B (600 Watt)
USB Devices (model/version number): 1 x KEyboard (Cherry Stream Multimedia or something like that), 1 x ThinkPad wireless mouse
1 x Gigabyte GC-WB867D-I (WiFi and BT card), connected in PCI slot 4, attached to internal USB2 header
Monitor: ASUS VX239H
CPU Cooler: HYPER 212 EVO
PC CASE: Fractal Design Define S
Operating system: Windows 10 Pro, Activated
Drivers Installed (include version):
ASMedia USB Root Hub - Version: 1.16.33.1
ASMedia USB3.1 eXtensible Host Controller - Version:1.16.34.2
Intel(R) USB 3.0 extensible-Hostcontroller - 1.0 - Version:10.0.10586.0
USB-Root-Hub (xHCI) - Version: 10.0.10586.122
Two "USB Verbundgerät", which I guess is a generic name for a Hub or something. Driver version is 10.0.10586.0 in both cases
I did run the FW update for the USB3 from the Support --> Drivers section
Any third Party temp/voltage software installed: No
System Overclocked (provide details): No
Hello everyone,
I hope this is finally the place, we I can get help. Friday last week, I started building my first PC (full partlist would be here:
http://pcpartpicker.com/p/CwzFwP ). Everything seems to work fine, and the system is fast and stable. However, there is one issue: My front USB3.0 doesnt seem to work. Here is what I tried so far:
a) Plug in the Front USB3.0 in the USB3_12 header
b) Plug in the Front USB3.0 in the USB3_34 header
c) try both headers without the WiFi PCI card
d) Reinstalling the xHCI devices in the device manager
When I connect the front-usb 3.0 to the USB3_12 header, one of the ports works. The other port only gives out power (my attached cell phone charges), but does not recognize connected devices. When I connect to the USB3_34 header, no devices are recognized.
Are there any BIOS settings that I should try? All devices are "enabled" in the UEFI, xHCI-Handoff is set to disabled
Are there any more trubleshooting steps that I should take? All the rear USB ports work fine.
Best regards,
Chris
