I have a new Gryphon build that only makes it through a cold-boot POST about 1 time out of every 3 or 4. I get the expected rapid sequence of CPU, MEM, VGA, and BOOT_DEVICE LED's, but... it hangs after a couple of seconds in the BOOT_DEVICE phase, my monitor stays dark, and I usually hear a small audible 'click' from any attached HDDs or optical drive. The BOOT_DEVICE_LED never goes out.
When I *do* make it through POST, the monitor lights up and I get the BIOS splash screen. I can either enter the BIOS, or let Windows (Win7 64-bit) load. As long as I make it through POST, the whole system works great and has for over a week -- I was able to install Windows to my SSD, copy my data files off old HDDs, install applications, and get back to work with Lightroom and Premiere. (Sorry, no games yet... hope you guys don't mind me hanging in your Forum.)
Once I've made it through POST, it seems like I can warm-boot, Reset from the BIOS, or Restart from Windows as many times as I want. Sleep and wakeup from Windows works every time as well. It's just powering down, and then pressing the power button back on, that seems problematic.
Things I've tried, none with any repeatable effect:
1) Tried both SSD and DVD drives as boot device
2) Reset CMOS with battery out (RTC reset to 1979 or something)
3) Re-flashed BIOS from stock (think it was 1007) to 1504
4) Updated Chipset, VGA, LAN, USB, and SATA drivers to latest from ASUS Support page
5) Changed PSUs from a 450W Delta OEM to a 430W Thermaltake TR2
Other than changing boot devices, I've been keeping the BIOS at all Default settings; in fact my memory is still running at 1333 MHz since I haven't enabled XMP settings yet while I figure this out.
Since this only affects cold boot, I am inclined to think it's a power sequencing or regulation issue, interacting with the Mobo somehow. But that's just a guess, one I'm not inclined to test with a ~$100 PSU purchase without further evidence. I'd love to be able to get some more insight into what's going on, if anyone knows where to find diagnostic tools for this board. I'm open to suggestions for other tests to try or components to check.
Or if anyone knows that BIOS 1603 addresses this issue, that'd be great too... ASUS is pretty cryptic about what each update addresses.
thanks,
Eddy
Intel i7-4770
Asus Z87 Gryphon, 1504 BIOS
16 GB G.Skill Ripjaws F3-1600C9D-16GXM
CPU/Mobo Graphics
256 GB Crucial M4, firmware 0009
2 TB WD Black WD2002FAEX
Thermaltake TR2 430W
