Gene-z not posting, LED give error 34
Retired
Not applicable
I've just setup a gene-z with a new 2500k and it is not posting. I get consistently error 34 in the LED and the BOOT_DEVICE_LED is red.
I've put only 1 4G stick in the slot farthest from CPU, removed graphics card, and still error 34
Upon close inspection, I saw that some pins were actually bended, and unbended them (now it looks ok at least visually). But it didn't change the error. I've also changed CPU (new unused 2600k), still same error.
Any hints? Look like I should RMA.
BTW, what do the LEDs display when the system has posted ?
16 REPLIES 16
xeromist
Did you strip the board down to bare minimum needed to post as listed above?
Retired
Not applicable
yep... and got a speaker now: 1x long, 4 short: hardware component failure... not very informative 😞
xeromist
Did you check the socket for bent/broken/missing pins and reseat *everything* (mem, gpu, cpu, power connections)? You may want to check the power connections to make sure none of the pins are pushing out the back of the plug as well.
Retired
Not applicable
yep...
i think about trying with another vga, also thinking about bringing the board back...
Retired
Not applicable
solved, it was a vga error anyways... different problem as the other guy here suggestd, got me on the wrong track 😄
Retired
Not applicable
hi bud,
would u tell me how did u troubleshoot it?
regars
2600K crossair 16G with cooler 240SSD vertex3
xeromist
Glad you got it sorted 🙂
