How is the CPU_OPT speed controlled on the VII Gene?
Is it mirrored to to the CPU PWM speed?
The problem is there is no CPU_OPT speed control option in the BIOS?
I am wondering if I can plug my H90 pump into the CPU_OPT and my radiator fan into the CPU header?
I have read that the pump should not be PWM controlled.
