Gen 3 Card will work on Maximus IV extreme Z?
MIVE
I was wondering am i able to use Gen3 card on Maximus IV extreme z?
Asus Maximus IV Extreme Z / i7-2600k / GTX 580 Direct CU II / 120 SSD Vertex 2 / 1GB seagate HDD
puma99dk_
yes u can put in a GTX 600 series or a Radeon HD 7900 Series that's PCI-Express but they will only run PCI-Express 2.0 not 3.0 since the motherboard as far as ino don't support PCI-Express 3.0
puma99dk| wrote:
.....but they will only run PCI-Express 2.0 not 3.0 since the motherboard as far as ino don't support PCI-Express 3.0
They are backward compatible, it may be change with Kepler, or if you SLI or Xfire 2 of them, but actual single pci-e 3.0 GPU don't run faster on PCI-e 3.0,
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/49646-amd-radeon-hd-7970-3gb-review-21...
HiVizMan
Level 40
I have used three on the M4E with no problems.
