Frontbase firmware upgrade issue
Szpiktor11
Hello!
I have a Maximus VII Hero and I also have a Frontbase. I tried to install the Frontbase driver, but it wasn't successful, than I tried to upgrade the Frontbase firmware, I guess it was successful, but after than that is nothing on the Frontbase screen, just a pale background light.
What should be the problem, how can I downgrade it?
Thanks
Legolas
FuryA
If the upgrade was failed, try re plug or use another ROG motherboard to check,
unfortunately, if it doesn't work just take to repair center for RMA
