Freezing and blu screen problem
NoLife
I keep getting blu screens or computer will freeze here is the report if anyone can help will give more info if needed thanks 2 all.what does this mean3027030271
Windows 10 64 pro
Intel I9 9900K Stock Speed
Motherboard -ASUS ROG Maximus XI Formula Z390
GPU-NVIDIA GeForce RTX 2070 Super 8GB GDDR6 PCI Express 3.0 Graphics Card - Black/Silver
Case-The Tower 900
PSU- EVGA Supernova 1000 PQ, 80+ Platinum 1000W
Memory- G.SKILL TridentZ RGB Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16Q-32GTZR
M.2-Samsung 970 Evo
11 REPLIES 11
Nodens
Level 16
Two words:) Unstable RAM.
RAMPAGE Windows 8/7 UEFI Installation Guide - Patched OROM for TRIM in RAID - Patched UEFI GOP Updater Tool - ASUS OEM License Restorer
There are 10 types of people in the world. Those who understand binary and those who don't!
RealBench Developer.
HiVizMan
Level 40
Yip I concur.
Chino
Level 15
sandro_c
Level 12
Hi NoLife ,
I agree with the previous advice that the problem appear to is the instability of your ram, but you have not explained how it is overclocked your CPU and your ram.
I use the same cpu and your same memory and if you wont to provide me this information maybe I can help with my settings of the ram that I have used it for over a year and were stable. I look forward to hearing from you.
Hello
sandro c
sandro c wrote:
Hi NoLife ,
Hello
sandro c
memory is just xmp enabled and cpu is stock here is a pic if this helps. thanks all for the help will do memtest
Windows 10 64 pro
Case-The Tower 900
M.2-Samsung 970 Evo
Arne_Saknussemm
Level 40
Yeah yeah, keep pedalling your hardware myths...it's faeries I tell you, MALEVOLENT FAERIES!!
** "Oh no, not again.....NURSE!!" **
HiVizMan
Level 40
We are on form tonight Arne. 😄 😄
HiVizMan
Level 40
Your Memory is OC'd could you have a quick look at the Memtest86+ guide I put together and run at the XMP settings and see what gets tossed out. Use the 5.1 version it is stable, but was not available at the time I wrote the guide.
sandro_c
Level 12
Hi NoLife ,
perhaps it is not an overclocking problems but could be an hardware defective, because with that memory I'm using a clock and timings most critical of your and does not give me any problems:
9-11-10-27-1 -98 to V 1,55 and memclocks around 2200 Mhz and cpu clk @4640.
It could be a memory stick failure.
Hello
sandro c.
