For anyone who has a 4790k running hot, here is the fix that worked for me
digmeahole1
I am not a novice and this is not my second post. Miserable site made me change my user name when i registered a new mobo.
I just put together a new rig with a maximus VII formula and was pulling my teeth out trying to figure out why my new devil's canyon was hitting 80c at stock clocks and a fixed vcore.
I had to manually input the turbo watts as asus bios auto setting is WAY out of line for this cpu. photo is below and cured my issues. fully stressed for 1 hour on an older corsair h80 vcore at 1.150 volts 4.6 ghz high tems of 64-69c now. Also vcore was jumping up even though i had llc disabled. I had to set the FIVR to balanced to get rid of that. The values are CORRECT asus for some reason multiplies whatever you put in the field by 8X! :mad:
Credit to koroziv for posting this on the intel forum! TY:D
hope this helps anyone who needs it. & Asus...you need to fix your bios for this cpu. Posted all over the net....
46155
"Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free" R.R.
30 REPLIES 30
hi,
I used this fix, had to put 256 too btw.
I had few questions about my rig.
I got my first Watercooling AIO (silent loop 360) and maybe i was expecting too much of it but i wanted to know if my temps are correct. I will try to provide the more infos on my rig and issues
I run it at 4.4 but i set the core at 44/44/43/42 so it's more often at 4.2.
I mostly use it for gaming and few video encoding for work.
My tems are 33/37 idle
In game it can goes to 60 for brief period of time but mostly 55/60 max.
i did a stress test on xtu and here are the results and temps : https://img15.hostingpics.net/pics/422113442.png
I used kryonaut thermal paste and added 3 extra fan for push pull.
My case is a Enthoo Luxe
Gpu : evga 1080 Ti FtW3
Intake
2 x140 fans on the front
1x140 on the bottom
Exhaust :
6 fans on the top -push pull
1 140 on the back.
Al the fans are silent wings 3
And last but not least there are some screenshot of my bios settings, maybe you guys have optimisation tu suggest :
https://www.dropbox.com/sh/rzsrl8gm43te6hm/AAB4_MSqQaPC8z5UiRR18107a?dl=0
Thanks
