First Attempt O.C. 2700k Maximus Extreme Z
Doco
Still pretty new to the overclocking business, so to start I went into the bios and enabled manual under the "extreme tweaker" tab, was feeling brave so set v core to 1.35 and tried for a 5.0 over clock on the maximum turbo setting, windows booted up, went to open cpu-z and it crashed, lowered the max turbo to 4.8, occt ran for about a min and a half before crashing, so upped the vcore to 1.37, ran for about 10 minutes this time before crashing, so lowered the max tubro again to 4.6 (kept the 1.37 v tho) ran occt for 1 hour (1min idle at start 5 min idle at end) large data set -using all the cores, it passed this test thankfully, again this is just my starting point, im sure I have alot more to tweak, I kept my ram at 1600 and also kept hyper threading enabled.
Maximum temperature ranged in the 68-73 region however the CPUTIN was around 68 aswell it said the CPUTIN MAX was 127? so ocassionally it would read CPUTIN spiking at 127 (literally for a second) then drop back to 68ish degrees??
Sorry I cant give much more info but again still rather new to this, would you like any of the 14 files occt creates when the test finishes?
edite new idle temp reads 25 dgrees in asus ai suite II and 37 degrees in occt il go by occt's atm lol
i7-2700K @ 1.33v 4.6ghz/ Asus Maximus Extreme IV-Z
Nzxt Phantom + Nzxt Havik 140
His IceQ7950 3G/Corsair VX550
Finally Updated to Windows 7! :cool:
26 REPLIES 26
Retired
Not applicable
This is in the swedish klimat, idle temp..
i5 2500k (h20)
Retired
Not applicable
The idle temp is not so important, stress the cpu a bit..
Retired
Not applicable
well, seems that you have a computer with a fine OC, and ok temp..
Chers to my bro in Irland, im crawling back into my cave for today, and sleep an hour or 2..
I Have new hardware to pic up in a couple of hours........
best get to bed then lol, hope you post the hardware you get
Retired
Not applicable
Nooooooooooooo the ones im getting, is a strict secret...;o)
Retired
Not applicable
If you planning to do more OC in the future, i recommend a new, or improved cooler,
Retired
Not applicable
You have a fine mobo over there, take good care of it, and it will treat you right..
Nite
