Hi;
You’re in luck.
This board is WONDERFUL with fan speed control.
I went through many 5 1/2 inch fan speed controllers in the front panel but in the end they ALL failed me…
- NZXT Sentry LX... Very nice 5 fan and temp controller. Main problem is after a few months the screen fads and turns dark. Have gone through 2 of these.
- Aerocool Touch 2000... Very nice touch panel but like the NZXT Sentry LX after a few months the screen fads and turns dark. Have also gone through 2 of these.
- Scythe KM01-BK KazeMaster... 4 separate fan RPM controls but the screen also faded after a few months. Have gone through 2 of these also.
- Scythe KM03-BK KazeMaster Pro... 6 separate fan RPM controls but the screen also faded after a few months. Had enough after only 1 of these.
Bottom line on most all front panel fan/temp controllers is the cheap LCD screens all start to fad after a few months.
My solution to this mess is three fold…
- I use the Asus AI Suite II (with custom fan speed/temp controls) that comes with the Crosshair V MB for separate control of the chassis and CPU fans (SEE: screenshots).
- I use AIDA 64 (Preferences\LCD Items) to create 4 separate screens that…
- The LCD screen on my Logitech G19 keyboard monitors at all times (SEE: screenshots).
The beauty of this system is I ALWAYS see the current state of my CPU, Temps and Fans no matter what is going on as the G19 screen is totally separate from the main monitor.
If you don’t have a G19 keyboard you can still see the same information that AIDA64 produces by setting up the same screens using AIDA64 Hardware Monitoring Sensor Icons on your main monitor.
WELL.... it seems that for some reasons the Forum is not allowing me to upload any JPEG's today so I will have to show you the screen shots later (when it starts working again).
Cheers;
Doc
Retired... and Loving it :cool:
