F2 problem Maximus - please help
Dbtboi
I am having the same error code but with mine it will start up show F2 on the debug LED and then shut off. It repeats doing then then at a random time it will stop restarting and just stay on. I am using a corsair Vengance as well do you think that would cause it to turn off and on though?
HiVizMan
Level 40
Hi Dbtboi I have started a thread for you as your system will be different and will need a different solution.
Could you please post up your full system spec's, what settings if any you have changed in BIOS and of course what BIOS version you are running.
