06-02-201004:42 PM - last edited on 03-05-202406:46 PM by ROGBot
1. What is maximum stable power that the cpu power circuit provide the cpu?
say vcc= 2v...... can the power circuit provide 2 x 400A = 800w? i'm just exaggerating. still i want to know the answer. 8 pin eps connector is 300w....but if we push the drivers and fet+ i'm sure we can push over 300w from a single 8pin eps connector...
2. Can we increase the switching frequency above 1000khz? Chil is very good im not sure if their controller can support 1200khz. I forget if the ocillators on the board can support 1000khz+. but i'll just ask just in case.
3. What is total capacitance and inductance before cpu?
# 1. I believe the motherboard CPU socket and power circuit is tested up to 600W i dont know if it was tested further, I suspect it can handle more power than that.
The single EPS 8 pin connector for CPU power is rated for ~400W
