Ethernet connection probleme
peter20ca
Last night my connection just went down and i've check a bit to solved the problem.
First i tryed to restart -> nothing change
Check in device manager, device is seen but always see this in the description of device
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
I then tryed to unistal and reinstal the driver nothing change again.
I tried a chipset update. still nothing
Tried bios update to latest version still nothing.
Check the cable the cable work on another device.
I can only see orange light on the NIC card so i guess there is nothing coming in.
Was wondering if someone would have any idea how to fix or ever had this problem.
I run windows 10 and ran it since release.
Thanks for help
peter
filmrissverleih
I had the same problem with my impact VII. It was a hardware failure with the LAN adapter. Only RMA could help!
Daniel
Daniel
I had the same problem but found that disconnecting the power to the PC for a couple of hours "cured" the problem.
