During use of OC_KEY monitor shows intermittent video problems.
sandro_c
Level 12
Hi guys
Do you have any experience of a problem on the OC-KEY not know, or if this is a known issue or bios ?: I'm still using bios 2105.
When you insert the OC_KEY between Samsung T240HD monitor and my video card HD 6970, initially working fine, but after 5 -10 minutes start to flash the monitor becomes completely dark for 1-2 seconds, as if he had lost the video signal and then return the 'image but sometimes shows small green pixels on the desktop, which seem to follow the outlines of images, while inside the windows that display data from the bios are OK as there was an intermittent problem of overlay.
The defect is always happening and it happens even if you do not press the activation button dellla OCKEY to reproduce the data windows, so it seems that the defect was created only by the presence or absence of OC_KEY: a different resolution does not change the default , but I use it with res. 1920x1200.
thanks to all
sandro c.
MB: Rampage IV Extreme 2105 bios
CPU: i7 3930K @ 4300 mhz stepping C2-1270 v vcore
RAM: 16GB Corsair Dom.GT 2133 - CMT16GX3M4X2133C9 @ 2133 mhz
Cooler: Noctua NDH14-2011
PSU: Enermax 625 MODU82 + silver
GFX: HD-6970 2GB DDR5
Disks: 2xOCZ Vertex4 Raid0-2xOCZ Agility2 Raid0 1TB Caviar-1WD
Monitor: Samsung T240HD 1900x1200
Pioneer Blu-Ray Burner
Windows 7 Professional 64-bit
DTHCoCo
same here , that is why i removed the key it is useless
HalloweenWeed
Level 12
The "OC Key" is lame and overhyped IMO. Not only that, it does not pass analog signals. If you don't have another computer like a laptop to OC and you have another keyboard to control it, the OC key be OK I haven't tried that - can't do both at the same time as they both need to use the same USB port. Otherwise the OC key onscreen overlay info is somewhat useless. Have you ever tried the ROG connect? It's awesome. It is not perfect, but works MUCH better than the OC key.
i7-3930K; Asus RIVE; G.SKILL Ripjaws Z 4x4GB DDR3 1866; MSI 7870 2GD5/OC; Crucial M4 SSD 256GB;
Corsair 1000HX; Corsair H100, 4x Excalibur 120mm PWM CPU Fan p-p, AS5; SB X-Fi Titanium Fata1ity Pro;
Dell U2412m IPS 1920x1200; Cooler Master HAF 932 case; Tripp-Lite OMNIVS1500 UPS fully Line-interactive.
(EVGA site: ) And I have a second (wife's) computer, Eve.
Overclocking is useless to me if it is not rock stable.
sandro_c
Level 12
Hi HalloweenWeed
I agree with you!
I will try today to connect ROG and if all goes well as you say, I think the OC_KEY will go the way it deserves ... that is lying in the bottom of a drawer!
CIAO
sandro c.
