Direction of Impact Power Card
benparker
Is it possible to change the direction of Impact Power Card? I only say this because the cooler I have (Zalman CNPS8900) they recommend the heat pipes come down in the direction of the IO plate direction. If I try this, then the heatsink touches the Impact Power Card and I have to fit in another direction and touches the ram stick but can get it to fit. If it is possible I would like to do this for a flush fitting.
I have the Maximus VI Impact
Windows 10 Pro x64 | Asus Maximus VI Impact | Pentium G3258 | MSI GTX 950 | 8GB DDR3-1833
0 REPLIES 0
