09-16-2011
08:12 PM
- last edited on
03-05-2024
07:53 PM
by
ROGBot
09-16-2011 10:11 PM
66racer wrote:
Hi guys,
1: Bus speed (fsb/ht) ALWAYS goes up one point higher than I set it, AMD is obviously 200 stock, but when left in auto in windows showed up as 201, set manually to 200, and still went to 201, I run an overclock 24/7 and find it irritating, loaded 230 which was my old setting and sure enough went to 231, I can set this down to 229 if I want 230 but dont think I should have too, is this a bios update issue or something I need to set in the current 705 build? THIS COULD BE DUE TO YOUR POWER SUPPLY PUTTING OUT A BIT MORE VOLTAGE not a problem its common
2: When I shut it down the OC lights at the bottom light up, manual says its so I know there is power to the board, cool, but I have an antec kuhler 920 and it gets power/signal from the usb header down there by the lights and the usb header has power to turn on the antec logo light on my cooler when computer is off, seems to be just the light since the pump feels off but a concern. NOT A PROBLEM BUT BE CERTAIN THE PUMP IS NOT RUNNING screw driver to ear test if you hear the motor its running
3. manual seemed unclear but can I plug a usb 2.0 header plug into the usb 3.0 one if I use the blue adapter thats in the package? I have 2 usb 2.0 mobo connectors for the case front panel alone plus I have my antec cpu cooler that needs one row (not a double one). Currently I have one front panel connector disconnected but thats a little issue at the moment. YES they are backward compatible
4: I was getting intermittent fan errors while at post causing me to have to enter the bios. I have a feeling the antec kuhler pump was spooling up and the mobo cought it below the 600rpm indicator, I have cpu fan speed control disabled so its 100% power, windows interface for antec tool shows pump working correctly too. Should I just leave the monitoring off or should I set to 100rpm or whatever the min is, at 500rpm it set the warning a few times also. IF THE COOLER IS PLUGGED INTO THE CPU FAN POWER/SENSOR CIRCUIT DEFINATELY but not familliar with antec cooling IF THE BOARD DETECTS A HEAVY LOAD IT WILL DEFAULT TO FAN ERROR
5: When going from stock settings to an overclock setting upon hitting f10 and yes the whole mobo shut off including fans then powered up and had the overclocked settings activated, is this to be expected? YES IT IS REBURNING THE CMOS DATA this is common on ASUS boards
6: Lastly and more of an observation than concern; I notice that the NB/vrm heatsink gets warmer to the touch than the msi mobo I had and since there isnt a built in temp sensor I figured I should ask if this is because the metal used by asus is better at transfering heat or should I get a temp sensor on there asap for overclocking? Where would be a good spot to put a sensor in that area? I want to get those temp probes and plug them into the mobo. For now I set the temp protection to 80C from stock 90C, I just wonder how the mobo knows the temp if we cant see it in windows 🙂 YES BETTER HEAT TRANSFER AND MORE HEAT PRODUCED allot of us are inquiring as to why there is no NB/SB temp readouts in bios as they are obviously monitored
7: Just to be sure, the asus driver cd had realtek audio drivers which I didnt install, I installed the creative soundblaster one on the Cd, under windows device manager I didnt see any unknown devices except the usb controller which Im gonna install right now since I just saw that lol. Im good right on the sound drivers? IF YOU'RE RUNNING USB SOUND YOURE OK disable the onboard sound in bios IF YOU PLAN TO USE THE ON BOARD INSTALL THE DRIVERS
8: I disables the ASmedia sata controller because I hated the post screen since Im not using it, but I left the ASmedia usb 3.0 enabled, will that cause any issues with usb 3.0 not working correctly? currently dont have any usb3.0 devices but the ports work 🙂 I have my 2 hard drives and sata dvd drive all on the SB sata controller (side one) Dont know Good One for Raja
If you read all that THANKS for attempting to help me out!! I appriciate it 🙂 you're welcome
AMD 1100T 4255mhz (oc with msi board)
Asus crosshair V formula
kuhler 920 modded for 2x120 radiators
corsair dominator gt 4x2GB 1866mhz 9-9-9-24 2t
msi gtx560ti twin frozr ii oc edition
corsair gs800 psu 800watt
corsair f120ssd series2/seagate 1tb 7200rpm hdd
rosewill blackhawk case - Asus cd/dvd burner
win7 pro 64bit - 1920x1080 display
09-16-2011 10:26 PM
09-16-2011 10:35 PM
66racer wrote:
Man thanks a bunch, that gave me some peace of mind.
About the fan issue going off what you said maybe it is just putting a bit of a load at startup or because of the higher load starts spinning slower than what the mobo expects and then throws that code? The pump and 2 120mm fans are how its set oem (cpu can 3pin and usb header plug) and Im thinking this asus board is "smarter" than most others and catches it, if others users have this issue with these coolers and this board im wondering if they need to have the mobo delay this test a second or so? The
Side note the antec kuhler 920 is from the same manufacturer of the corsair h70 series but with an updated copper surface. Always forget the names. Its funny corsair and antec swapped suppliers on their latest series of coolers.
09-17-2011 04:12 AM
10-05-2011 08:21 AM
10-12-2011 06:39 AM
