Crosshair V Using 3rd 4 pin power Connector
ravfour22
Hi to all.
At current time I am using a HX850 Psu Corsair. I did get extra 4x2 Psu power plugs. I am using the 2x4 cpu connector or eax on the board. I wanted to use the extra 4 pin, but when plugged in it gave strange results with video, using 3 displays? Does anyone else out there use all 3 of the eax connectors on a crosshair V mobo.
Thanks in advance.
Fx-8150, 4.5GHz, 1.34v. H70 Cooling, Corsair Dom 2 X 4Gig 1866MHz 9-10-9-27-2T-1.5V, Crosshair V, Hx850 PSU, XFX B.E. 7970 DD, 3 X 23 Led's, 2 X 1Tb Blacks, 2 X 2Tb Greens, 5Tb NAS Cloud, Logitech Mx Mouse, Logitech 7.1 surround,
Life is what you make it.
stock12to32
I use all 3 power plugs on the board.
The 2 EATX12v plugs on the top help give an even power distribution through the board when overclocking but only one is needed(From what I have read from others).
The other power plug in rear middle of board above PCIe slots are for the PCIe slots and it does need a 4 pin molex plugged into it when using multiple graphic card is how it is stated in the manual.
3dMark11: P13350
http://www.3dmark.com/3dm11/6105510
System:
ASUS Crosshair V Formila BIOS 1703
AMD FX 8350 @ 25x 200 = 5Ghz (water cooled)
16Gb Patriot Vipper Xtreme DDR3 2133Mhz
x3 ATI HD6970 trifire @ 920Mhz GPU and 1400Mhz Memory
x2 128Gb Samsung 830 Series SSD RAID-0
128Gb OCZ Agility 3 SSD
x2 1Tb 7200RPM Hardrives RAID-0
LEPA 1600W PSU
Thermaltake Level 10 GT Snow
x3 27" ASUS LED LCD (eyfinity)
LG Blue-Ray
Logitech G110 Keyboard
Logitech G500 Mouse
Windows 8 64 bit
