Crosshair V no boot + cpu_led light red
sam46952
Hi people,
Just recently purchased a crosshair v and amd 8150 cpu and set everything up but when i go to turn my pc on i just get all fans powering up and the red cpu led light on the board... externally the usb ports get no power and there is no display on the monitor... I have read through as many threads as i could find and have tried swapping out all the parts with my old amd rig which is running a 1100t and resitting parts several times but still to to no avail still giving red cpu light. I was able to make it to the asus splash page once by resetting the jumper however after that one time it has not worked ...
currently running -
mobo: CHV
CPU: amd 8150
GPU: 2 x 580gtx
PSU: ocz 1250w
RAM: 16gb corsair dominators
tried swaping parts with -
1100t
ddr3 rip jaws
6950 gpu
Anything else i can try? oh i have also tried rebuilding it outside of its case... still red cpu...
Is my only option now to rma?
7 REPLIES 7
thethat
The 8150fx cpu needs a higher bois to run on your motherboard.
Insert your old CPU, flash your bois, and it should work.
NemesisChild
Level 12
Install the 1100T, one stick of memory (furthest slot from CPU), and one GTX 580.
If the post is successful, flash to the latest bios listed on the ASUS support website.
Once completed, you can then install your FX-8150.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
thanks for the quick reply guys, my motherboard revision is 1.01 which should be running 813 bios which from my research shows should be compatible with the 8150, as mentioned above I have tried booting with the 1100t however I still get the cpu error LED so i am unable to reach the bios screen, I have tried booting with the minimal amount plugged in as well... 😞 ie 1 stick of ram and one gpu...
NemesisChild
Level 12
Ok, re-read your posts, only two common components here are the MB and PSU.
Do you have only the 8-pin CPU power connection to the board?
Can you test another PSU?
If the 1100T has all pins intact (none broken or bent), then I would say RMA the board.
sam46952
Hmm I tried my 850w antec same problem lols... yeah 8 pin is connected... should 4 pin on the mobo have anything in it ? manual says one or the other I think... also checked the 1100t pins look intact zzz gonna have to RMA the thing get it back after chrissy probs 😞
NemesisChild
Level 12
No, the extra 4-pin is not really needed unless doing some extreme CPU overclocking.
Yeah looks like your best option is to RMA the board, a not so Merry Christmas I'm afraid.
well gonna RMA the thing today wonder how long its going to take... apparently I can just drop it off the service centre since its on my route home....
