Crosshair V Formula Z, BIOS Problem,I need help!
MeanMachine
I have just finished a new build and have been trying to configure the latest Bios update. After checking it out and doing a little tweaking, when I rebooted after accepting the changes it came up a request to enter a DVD in the correct drive to continue.
I reboot and enter the BIOS to check my boot option and now the only drive it recognizes is my DRW drive. I'm not very familiar as yet with the BIOS so could some GURU please help?
Up to now I have reset to default with no change. I cant see anything in the Bios boot priority that will allow me to prioritize my SSD which has my OS installed and was originally setup to boot from. I also have a 2nd HDD which isn't recognized either. All drives were there and seen by the BIOS prior to the update, so yea WTF! The BIOS just dont see my drives anymore.:mad:
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
iman05
Connect a usb external HD to it and see if the BIOS sees that. If so that doesnt look goed, try reconnecting your HDD in your SATA port and see if that changes anything.
Case | CM HAFX
MoBo| ASUS MAXIMUS vi Formula
CPU | 4770K
CPU Cooler | Corsair H100i
RAM | 4x4GB Kingston HyperX Beast 1600MHz
GPU | MSI GTX 780 Twin Frozr
Sound | SoundBlaster Zx
HDD | Samsung 840 EVO 240GB
PSU | Corsair RM1000
Well that's interesting and thanks for your response iman05. In updating the Bios all settings were set to default and the section regarding SATA connections had all switched to off. My doing as you suggested switching ports I tried but that didn't help so I started digging deeper into the BIOS and Voila tous bien.
Love your country btw, I was born there. St Hubert.
My System Specs:
CPU:
[/HR]
Glad to hear everythings ok! viva la Belgium hahah 😉
Case | CM HAFX
CPU | 4770K
