Crosshair V Formula Z & Supreme FX III Sound Playback Issues
BlackhatEspeed
Hello,
I'm currently having problems with my build. When I start up my computer it's having a lot of sound issues. 2/3 boots I will have no ability to change the playback devices from the system, it simply wont open the playback devices. I have to re-boot 2-3 times before it will allow me to open programs like Skype, Teamspeak, or Ventrilo. Anytime you open a game or use anything that uses the current sound device it stops me from opening the sound link under control panel completely. However after I reboot a few times eventually everything in the task bar will load much quicker and I'll be able to use the computer as normal.
I'm running Windows 8 Pro 64 Bit,
I'm using a 50" LED TV as my monitor.
It seems like after I go to device manager and uninstall the Realtek HD Audio device driver the playback devices instantly shows up. I've tried installing and uninstalling the drivers from Asus's website and from Realtek's website.
Any help would be greatly appreciated.
It also freezes firefox up often, I've tried disabling the sound card completely and it still locks up and freezes and playback devices wont open. I think this is something driver related.
MB: ASUS Rampage VI Apex
CPU: Intel Core i9-9900X 10 Core OCed 4.5GHZ
RAM: Corsair Dominator Platinum RGB 32GB DDR4-3600
PSU: EVGA SuperNOVA 1600 T2 80+ TITANIUM, 1600W Power Supply
GFX: Zotac 1080 Ti 11GB Mini
VROC: 2 x Intel 7600Ps 512GB
PCH: 2 x Intel 7600Ps 512GB
SSD: Samsung 850 Evo 500GB
MON: Acer Predator X34P 34" Curved Gaming Monitor 120HZ
CASE: Cooler Master Storm Trooper (Window)
LCS: Corsair H115I RGB Platinum 280MM
OS: Windows 10 Pro 64 Bit
sectionate
Level 12
the onboard is trash lots of people have problems with it. There is a huge thread on this forum with a half dozen possible fixes, I couldnt find it for u
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
Redwing3139
How did you disable the sound card?
