Don't worry...we have a lot more trouble-shooting to do here which WILL be labor intensive just so you know.
First off we need to check that you have BOTH of the 4-Pin AND 8-Pin Aux CPU connectors populated (trust me on this one).
Secondly we need to check that you have the EZ Plug (molex connector closest to the CPU socket) populated; especially with two graphic cards
Be sure to remove all expansion cards; all usb devices (including the keyboard and mouse)
Next pull one of the graphic cards and only have one stick of memory in the motherboard (see the manual for which memory slot to put it in)
Now attempt to power-up the system...will the system even POST?
If not I think one of four things are messing your system up:
- try swapping the out the other graphics card
- try swapping out another RAM module
but I think this is where the problem really is:
- bad PSU
- Faulty H100 cooler (make sure to pull the USB cable out) and replace with the stock cooler (or at least connect your old cooling fan header to the CPU Fan Header on the m/b...if the m/b can't detect a fan spinning I believe it would cause the M/B to act as it was "broke" and attempt to access the BIOS)
This should keep you busy for awhile...post back with what you find out and please let us know what the "fix" is/was.
[/HR]
For trouble-shooting tips see my blog at:
[/HR]
http://thenerdbench.blogspot.com/p/bench-testing.html
[/HR]
MB: Crosshair V Formula-Z • CPU: FX-8350 • GPU: Asus Matrix R9 280x • RAM: 8GB of Crucial Ballistix Tactical Tracer (1866)• PSU: Thermaltake DPS Thoughpower 750 Watt • CPU Cooler: Thermaltake Frio Advanced • Keyboard: TT Sports Challanger Ultimate • Mouse: TT Sports Black Element • Case: Thermaltake GT Level 10
[/HR]
