Hi rog_panda and Welcome to ROG
As you are interested in how to overclock your system properly, then I suggest you first get to know your Bios.
There are a number of good tutorials and Vids that will help, and only OC using your Bios and not within your OS.
First you should populate the 4pin for stability and your PSU is adequate at 1000W.
To test for stability I recommend using RealBench and HWMonitor to observe temperature and voltage fluctuations during stress testing.
These are key to a successful and stable OC.
First is to establish a stable base clock frequency, you then raise your multiplier a small amount, then reboot and if unsuccessful, you then up your CPUcore voltage a small amount to see if that works. If stable then increase your multiplier and voltage ((Small amounts), rinse and repeat.
Eventually you will reach a wall and no matter what you try you will not have stability.
This of coarse depends on the capability of your CPU and no two are the same. It will take patience and time and many reboots and tests before you are done. You should also save profiles in your Bios as you go, to save having to start from scratch.
Here are links to some Vids and Tutorials:
https://www.youtube.com/watch?v=-kOlBalkVyAhttps://www.youtube.com/watch?v=MckeAmnDeTkHave fun and please report back with results. For specific problems re: Extreme Tweaks and settings, just ask
MM
BTW, Please fill in your system specs in your profile so we know your system.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
