12-14-2013 05:04 AM - last edited 3 weeks ago by ROGBot
12-14-2013 06:46 AM
12-14-2013 06:53 AM
Myk SilentShadow wrote:
If you're having problems with one of the PCIe slots, I would recommend sending the board in for RMA. If you were to get an CHVF-Z, a clean install is highly recommended to ensure everything works smoothly 🙂
12-14-2013 08:45 AM
12-14-2013 09:24 AM
chrsplmr wrote:
* The last one is probably a no. If it is still under warranty and 'deemed inoperable' 'they' would probably do as the warranty
agreement calls for, replace the board or fix that one.
Heatshiver - Welcome to ROG.
First. There are procedures in the manual for clearing the cmos. With the computer powered down, but the psu on,
push the 'green lite refresh button' in the inputs. 2nd .. the jumper method, mb powered down, psu off, push and hold
power button to drain the mb and then move the jumper .. and then move it back. [just for future knowledge]
A few questions.
No post ? Not going through the led sequence at all ? or if yes, hanging on gpu ?
Zero video ? as in, can not get into bios ?
Have re-examined the gpu ? any blown 'caps' ? Any on the mb ?
When you say 're-paste', do you mean the gpu .. or did you repaste the cpu as well ??
If yes, have you tried reseating the cpu again ? check for bent pins ? (no offense-just blind troubleShoot'n bro)
And how sure are you of the psu ? is the aux. plug in ? [i doubt this is the problem, but one never knows.]
By your post, if I understand you correctly, there is No post-No beep-No red lights, but all the fans turn on ?
Very curious. Please keep us 'posted'. .c.
12-14-2013 09:43 AM
12-14-2013 09:55 AM
chrsplmr wrote:
Post here whenever for whatever. Never a problem here.Very curious that no leds light in the group next to the power block.if that 700 is still working u might want to plug that in to be sure.If u have the funds and are keen on upgrading to the Z. When they get the RMA sorted u will have a backup ... or sell it.Something not to funny going on. mb. psu or gpu.Is there a mate with a mb you could test tha gpu in ??? btw..c.
01-14-2014 12:05 AM
