First, let me welcome you to the forum !
I think you are questioning the difference between the CPU temp and the CPU Core temps?
The reason for the difference is because the CPU temp is being read from a thermistor that is mounted on the MB under the the CPU socket itself and the CPU Core temps are coming from a diode inside the CPU itself. The reason the Core temps are all the same is because all the core temps are coming from the same diode. The temps you need to be concerned with are the core temps, you want to keep those @ 55c or less.
I hope that I have answered your questions adequately?
Electronic Smoke Signals From my TechnoTeepee
ASUS Crosshair V Formula AM3+ 990FX, 1703 bios
AMD FX 8350 Vishera @ 5162Mhz [21x245] 1.546v 🙂
Water Cooled - Koolance EX2-1055, CPU 370 WB, Idle=22c Load=52c
32Gb G.Skill Sniper ddr3 1600 8G X 4 , 9-9-9-24 @ 1.55v
ASUS HD7970-DC2T-3GD5, Cat 13.5 beta 2, Dell U3011 @ 2560x1600
SanDisk Extreme 120Gb SSD SATA 6Gb, 250Gb SATA 6Gb, 1Tb SATA 6Gb x2
Win 7 Ultimate 64bit, Corsair Obsidian 800D, Corsair HX1000w PSU
