CPU LED, 00 Q-Code, about done with Asus boards
ChaoticTheory
So, finally got in my new components (see other threads) as shown in my signature. Hook everything up, hit power, NOTHING! 00 Q-code, CPU LED lit red. I am beyond frustrated at this point, and so far past the due date to have this computer running I am at a loss for what to do. Hopefully someone here can help me solve this so I don't have to RMA ANOTHER Asus board. I am about to switch to a different brand, but I really like all the features the ROG boards have.
Here is what I have done so far:
Currently only have CPU/GPU/PSU (24/8/4 pins)/1 stick RAM (currenlty the MEMtest verified Corsair Dominator GT, still waiting on G.Skill RAM so I can return the GT ram)/Fans and front panel connectors
Cleared CMOS
Updated BIOS to 4102 using BIOS Flashback (FAT32 USB stick with R4E.CAP in ROGConnect port, hold ROG button until flashing)
Tried re-seating CPU, checked to see if there were any bent/broken pins (none seen)
Contacted Asus support, they had me remove all the RAM and test it, same result. They said bad board or CPU and to RMA, which will take a week before they can ship it out, if I give them a credit card as collateral.
Anyone have any other suggestions?
CPU: Intel i7 3970X
Mobo: Rampage IV Extreme
Memory: 32GB (4x8GB) G.Skill RipjawsX 2133MHz
GPU: Sapphire HD 7990 6GB
Cooling: Dual Loop Custom Cooling
Koolance Dual Bay Resevoir with 2 Swiftec MCP655-PWM pumps in parallel
Loop 1: CPU Dedicated with Triple Rad Alphacool UT60 Push/Pull
Loop 2: GPU Dedicated with Dual Rad Alphacool UT60
PSU: OCZ ZX 1250 Watt
Case: Corsair Obsidian 800D
47 REPLIES 47
ChaoticTheory
I purchased through Amazon, they won't test it, and I really hate to RMA both again. Crossing my fingers the board is the only problem and the next one works perfect.
CPU: Intel i7 3970X
minimic
One last thing: Did you test another PSU, because that could also be the culprit.
[MB:Asus Rampage Gene IV]/[CPU:I7 3930K C2]/[RAM:4xGskill TridentX F3-2400C10-8GTX 9-9-9-24@1600MHz]/[GFX:POV TGT GTX 670]/[CASE:Siverstone FT03]/[WC:NexXxos ST30, NexXxoS UT60,HeatKiller 3.0, laing d5]/[FANS: 5x120mm]
ChaoticTheory
If I have problems with the new board I will give that a shot, I have a spare PSU I can test. Too bad I don't have a spare LGA2011 CPU and motherboard 🙂
CPU: Intel i7 3970X
ChaoticTheory
Success! New Mobo posts just fine. Updated BIOS and installed my new RAM, currently running it through the gauntlet of MemTest before I install the OS. Any other hardware tests I can run? Any suggestions, recommendations, opinions, etc. that anyone wants to offer as far as initial install and setup? Installing Win7 Pro, 1x256GB SSD, 2x128GB SSD, (all Samsung 840 Pro).
Also, the Crosshair mobo had GameFirst application for controlling and prioritizing network use, is that available for the RIVE?
CPU: Intel i7 3970X
HiVizMan
Level 40
Mate keep it simple.
You do not want to clutter your board with all those add ons. And thankfully no the REIVE does not have that thing. 🙂
ChaoticTheory
What add-ons are you referring to? I was planning on keeping things as simple as possible, but also want to ensure a good system. If a program/feature/setting will help then I want to use it, but if it's not worth it I will avoid it. That is why I am asking the experts 🙂
And I take it you aren't fond of the GameFirst program, is is not very effective, not worth the resources, etc?
CPU: Intel i7 3970X
AAAAARRRRRRRGGGGGG Saved up for ages bought everything together got the new hero board as i liked all the gadgets that come free.
Watched JJ on Youtube to make sure everything was done correctly.
It arrived checked everything as per tutorials then built up nice and steady flicked the switch all fans started HDD and dvd span up .......
00 cpu led glowing bright red, followed all the instructions on all websites still red light of death £1500. quid of useless metal plastic and silicon .
last straw was being told to put a different processor in!!!!!! like i have intel i7s lying around.
Hello
Not having spare components is a definite hindrance when assuming the role of a system integrator. If spare parts are not available RMA both the CPU and motherboard. When the replacements are received use extra care placing the CPU in the socket and tightening the CPU heatsink assembly.
