CPU fan speed is stuck at 480RPM with Maximus VII Gene
Anusha
Yesterday I got my M7G board. I'm having a problem with the CPU fan speed. It doesn't ramp up past 480RPM.
The CPU cooler is Silverstone Heligon HE01. It has a big 140mm fan with PWM connection. The fan is plugged into the main CPU fan header. I didn't try the optional one.
At first BIOS couldn't detect it at all. 0 RPM. Then I qdisconnected and reconnected. Then it could be detected but the fan speed is very low compared to the 2000RPM which it is support to operate at.
I ran Q-Fan control and the results show that the fan operates at the same speed - 480RPM - regardless of the PWM signal. I had this cooler in my Maximus VI Hero up to now and I just set it to Standard and it worked perfectly.
Why doesn't it work in the new board?
I'm using the latest 1002 BIOS.
I also tried AISuite and it also came up with the same results.
What should I do?
HiVizMan
Level 40
I think because the fan is running lower than 600 rpm which is the default it may be a good idea to set the lower limit to 400rpm and see how that goes.
Nice blog by the way. 🙂
It was the fan. Something killed it. I just cannot figure out what caused it. It was working just great on the M6H. Mobo switch and the fan's stuck at 500RPM.
Thanks 🙂
Raja@ASUS wrote:
Anusha already has a reply to this over on OCN :
http://www.overclock.net/t/1488891/asus-z97-motherboards-official-support-thread/510#post_22600559
And I had to link it here too:
http://www.overclock.net/t/1487530/asus-z97-republic-of-gamers-motherboard-owners-club/520#post_2260...
Anusha, if you dont get a reply for a few hours its usually due to people being on a different timezone to you. I noticed there was a thread here on Sunday night from you that was on OCN two hours later. It's not because people are ignoring you - you just have to wait til people are online and they get to you. 🙂
My bad. I was really feeling bad about what happened.
Raja
