02-16-2015 03:35 PM - last edited on 03-06-2024 03:33 AM by ROGBot
02-16-2015 09:44 PM
Wallboy wrote:
Under Advanced > System Agent Configuration > CPU Display Audio. Does anyone know what this actually does? Thanks.
Allows the CPU to support audio if CPU has this capability, Enable or Disable. Just how it works exactly idk.
EDIT: Also just another little question. I'm reading through the VII Hero Manual and it says it has DirectKey, and even has a setting in the BIOS for it, but from what I can tell, these boards no longer have a DirectKey button or it's associated 2-pin connector. Is this right?
02-18-2015 04:22 PM
