08-10-2014
04:01 PM
- last edited on
03-05-2024
10:32 PM
by
ROGBot
08-10-2014 08:23 PM
08-12-2014 11:47 AM
MeanMachine wrote:
G'Day Nepty.
Specs for CVFZ are for 32GB max, however theoretically maybe more, but a waste imo.
It is best to select DIMMs in kits, which are tested as a kit. Mixing kits can work however it is not recommended.
From default settings in Bios you can determine your XMP profile and timings using CPUz.
Tested Latency for yours are: 9-10-9-27 @1.5v
Set the XMP profile settings in Bios to start with,then run a stress test. Best test for DIMMs is Memtest86.
If stable @1866, stick with it for best stability and save a profile in Bios.
An increase in voltage say 1.65v and other Bios tweaks will allow OC however it depends on the strength of the IMC, damage can result from excessive stress and kill your CPU.
Best results are obtained with small increases of Frequency and voltage, and will determine success, so monitor carefully.
Myk SilentShadow wrote:
If you want that 1866 kit to run at 2133, try selecting the 2133 frequency, go to DRAM Timing Control and set the 4 values to Auto and set the DRAM Voltage to Auto also. F10 to save and reboot and see how it goes. If you get a successful POST, you know your 9590's IMC can handle the frequency, go back into your BIOS and timing control again and see what values have been set and see if they're much different from the ones listed on the Hightechlegion test's table.
08-10-2014 09:22 PM
