CMOS Battery Question
crazymilk
I have only had the Mobo for a couple of months but the time in the BIOS keeps changing after each boot - which effects the time settings in Win7.
All my OC settings dont change just the time.
Would this mean the battery is going?? It seems unlikely as the mobo is only a few months old
6 REPLIES 6
kkn
Level 14
if battery is dead bios would be stock on each bootup.
so no go there.
there is a tread about tge bios watch some where here.
cant find it as of now since im on the cell here.
NemesisChild
Level 12
It's been an ongoing problem with certain bios versions, here's one thread:
http://rog.asus.com/forum/showthread.php?42276-Asus-Mb-bio-s-wont-hold-OC-ing-settings-and-puts-CPU-...
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
HiVizMan
Level 40
http://rog.asus.com/forum/showthread.php?36676-Frozen-Time-Clock-in-UEFI-The-Fix&country=&status=
crazymilk
Great
Thanks I will try the fix later when I get home.
Could somebody tell me where to get that MEI driver from?
HiVizMan
Level 40
Should be on the motherboard support page.
HiVizMan
Level 40
