Audio problem Asus Rampage Extreme IV
Superpapu
Hello people, Im new in the forum and maybe someone can give me a hand with that. I have a board a Rampage Extreme iV. My config is a asus rampage extreme, 3960X, 580gtx, 750 ocz fatality and 4 hdd.
The problem is that the mother doesnt recognize the speakers I plug in the mother and usb (just for power) and win 7 doesnt recognize. I try with a usb headset and work but with speakers with plug no. Also I update drivers and bios I got into the bios and the card is enabled, I try in hd, ac97, spidf, hdmi no one recognize. Win just recognize digital out, I add a picture to clarify that. I also try with an iphone headphone and doesnt work.
http://imgur.com/Oc2gvJf,faeulta
Thanks!!!
4 REPLIES 4
ChiefZeke
The motherboard has USB 2.0 and 3.0 ports - are you connecting to the correct version? Check the manual for which is which.
Lian-Li PC-A77F Full Tower case
PC Power & Cooling Turbo-Cool 1200 ATX12V & EPS12V PSU
ASUS Rampage IV Extreme LGA 2011 X79
Intel Core i7-3960X 3.31 LGA 2011 CPU
Intel RTS2011LC Liquid Cooling Solution
Kingston KHX24C11T3K4/32X (quad 32Gb memory kit) 2 each
ASUS Radeon HD7970 DirectCUII 3Gb GDDR5 PCIe 3.0 x16 Video Card (two in CrossfireX Mode)
Western Digital Cavier Black 2Tb SATA III 6.0GB/S
OCZ Technologies Vertex 4 SATAIII 6Gb/s 512Gb SSD
VVojtas10
For me, audio doesn't work on that mobo. I have tried everything.
ChiefZeke
Audio working just fine here.
Holden
Hi, could you please tell us which cable your connecting to the motherboard is it the case front panel cable with ac97 and hd,
I usually plug the hd end (case cable for front panel audio) to the motherboard and then set the hd in the bios,
then connect a device to the front panel port whilst in windows and load the drivers and the software included on the disc
