09-05-2013 09:24 AM - last edited on 03-06-2024 07:49 PM by ROGBot
09-05-2013 10:43 AM
09-05-2013 11:25 AM
09-05-2013 11:54 AM
09-05-2013 12:56 PM
09-05-2013 01:01 PM
KingShinobi wrote:
Ok thx, but the spectre should work as well, right? 0,11A do they say on the bitfenix homepage
09-05-2013 04:17 PM
KingShinobi wrote:
HAll together I want to install four case fans, all 3-pin.
My question are: Can I use a PWM splitter like this one to combine the two top fans? http://www.akasa.com.tw/update.php?tpl=product/product.detail.tpl&no=181&type=Cables&type_sub=Fan%20...
09-06-2013 12:30 AM
09-06-2013 05:46 AM
KingShinobi wrote:
Thank you Praz. Chino already suggested a simple Y splitter, which will work and also not overload the header, since the fans only operate at 0,11A.
09-09-2013 01:28 AM
