01-12-2018 06:11 AM
01-12-2018 06:59 AM
01-12-2018 08:23 AM
01-12-2018 09:05 AM
KSMerg wrote:
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/Z170-A/Z170-A-ASUS-3703.zip
01-12-2018 09:25 AM
01-12-2018 09:15 PM
01-13-2018 09:24 AM
Broheim wrote:
So after 3703 appeared on ASUS Z170-A BIOS download page today, I updated to it - it still doesn't solve the problem with Error 8719. MEUpdateTool doesn't update ME firmware. Intel-SA-00086 Detection Tool reports that the system is vulnerable, same result with running FWUpdLcl64.exe -f ME.bin, Intel MEInfo 11.8.50.3425 also reports Local FWUpdate as Disabled.
Is ASUS going to fix this problem or not? Or am I stuck with a vulnerable firmware on my motherboard, when it is a fairly recent model?
Furthermore, they should fix their MEUpdateTool because it misleads users that their system was updated and, therefore, safe:
When in fact, it wasn't updated and is still vulnerable:
01-13-2018 11:11 AM
Insert_Coin wrote:
Hi.
Does this means that this new bioses that are being released with the updated microcode doesn't come with the ME update?
01-13-2018 11:24 AM
01-13-2018 12:16 PM
th3rookie wrote:
@Broheim DId you tried to see if Local FWUpdate was set to ENABLE/DISABLE using MEInfo Tool ?
To downgrade your bios, you can try with Winflash with the command prompt using Winflash /nodate.
I don't have the same board (Sabertooth Z170 Mk1), but I was able to flash the new ME using a 3xxx Asus bios (3401)
KSMerg wrote:
https://forums.overclockers.ru/viewtopic.php?f=25&t=447045
It is possible to update the firmware first to 11.7.
https://forums.lenovo.com/t5/Lenovo-E-H-K-M-Q-Y-and-ErazerX/300-20ISH-Desktop-ideacentre-Error-8719-...
