Asus Rampage IV Extreme + Corsair H100 research/help
StarFyre
Hello,
I'm doing a 'baby' upgrade from current Rampage III Extreme to a Rampage IV Extreme in the coming weeks. (new cpu of course!)
In doing so, i got an H100.
But, i noticed that while some seem to have no issues, there are lots at the corsair forums who have issues with the H100 on the Rampage IV. In the end, it appears to fit but with many difficulties.
I'm still confused a bit as i've heard people say both; change the backplate vs not changing it, etc.
Can anyone here, give the impressions they have if they have done it and what to look out for and if it works/how to do it in the easiest way they found?
Regards,
Sanjay
26 REPLIES 26
Jobeo
no you definitely don't change the backplate... the way the R4E comes is exactly right for mounting the H100...
i too was very concerned about the mounting issues before attempting to install it... the fix is very simple though... if the holes don't line up just right the first way you try... just rotate the head 90 degrees and they should line up perfectly...
i think the issue is that people want the head to be a certain direction... and don't want to consider rotating it 90 degrees.
Rampage IV Extreme
3930k C2 stepping intel cpu
Gskill 32gb kit F3-17000CL9Q2-32GBZH
GTX 760
GTX 560ti
Areca 1882 Raid Controller
Crucial m4 SSDs 256gb two disk raid 0
Enermax 1350w maxrevo PSU
Cosmos 2 case
Retired
Not applicable
Some h 100 fit, and some dont, so well
Baalberith
I had to change the backplate for the X shaped one on the H80, otherwise i had to put too much force on 1 of the 4 pins to make it fit.
Intel Core i7 3960X 4.4Ghz @ 1.28v
Asus Rampage 4 Extreme
32GB Corsair Vengeance 1866 Reds
Corsair H80
Corsair AX1200
2 x M4 Crucial 128GB
3 x 2TB WD Black
2 x XFX GTX285 BE
Dell U3011
InnervateD
Spoken from someone who has experience with this and spent some time looking at all the different ways to mount it.
1: You don't need the X-Bracket if you have the 2011 Screws.
2: I you want to Mount it the correct orientation with Corsair reading Corsair without it being slanted on the side, you might need to do the following:
- Take a pair of pliers and bend all 4 tabs upwards just a little not too much, if your worried about scratching the black paint on the tabs, take a cloth and cover where your pliers will be bending.
- Loosen up all 4x LGA2011 screws on the LGA2011 bracket, as in have them screwed in a bit but only half or maybe a quarter of the way in, then place the water/pump block on the screws (it might be tight and you might have to force it down a little with some force but it will go in without too much trouble), and start screwing in the thumb screws in to tighten up the 4 screws. Do this evenly by doing say top left then bottom right, then bottom left top right.
3. You can mount it with almost ZERO issues if you mount it on the side with the waterblock reading Corsair reading upwards instead of horizontally.
Number 2 worked for me and that's how I got mine installed. It's tight, very tight but it works.
Necrosan
Level 12
I own the H80 and do not use the X-Bracket at all.
LGA2011 mounting screws worked just fine.
MB: ASUS Rampage IV Black Edition
CPU: Intel Xeon E5-2697 v2 (Cooled by Corsair H100i w/ Noctua NF-F12 fans)
RAM: 64GB G.SKILL RipjawsZ 1600 (10-10-10-30)
GPU: EVGA GeForce GTX Titan X Hybrid
TV Tuners: 2 * Hauppauge HVR-1800
Case: CoolerMaster Cosmos 2
tadhp
With the up right orientation, I can't force it down, mismatch so big.
Not sure if I bend the tabs, the block still sitting flat on the CPU or not.
Almost do the item 2 same as InnervateD wrote above, but I decided to rotate it 90 degree counterclock wise
and the block just go down smoothly.
I don't like its look but I like how its fit just right, no force, no stress, no worries
Your call StarFyre
BTW when I'm not OC , my CPU temp is between 26 to 29 degree C. Is it normal like every one with the H100 ?? TIA
7564
CPU : Intel i7-3960X MB : Rampage IV Extreme 3101 Mem : G.SKILL F3-17000CL9Q2-32GBZH
GPU : MSI R7970 Lightning PSU : Corsair 1000W OS : W 7 Ultimate Corsair H100 Water cool
SSD : 120GB Kingston Hyper X SSD : 512GB Samsung 480 Pro HDD : 2X 1T WD Speaker : Bose companion 5
Cooler Master
HAF-X Monitor : ASUS PB278Q
Jobeo
mine is rotated 180 degrees from the last pic... i found the hoses were less resistant that way
Rampage IV Extreme
GTX 760
GTX 560ti
Cosmos 2 case
Im not sure about other people, but i know mine installed perfectly fine with the corsair name being linear to everything else. All i had to do was swap the x socket backplate (my r4e came with it on) with the 2011 backplate and it was done. However perhaps it is a hit and miss with the h100 fitting as i know mine is defective (one of the fan ports on it doesn't work and i cant change the speed of the pump with the button on it)7565
Ignore the cable mess, its a work in progress 🙂
My Build
I7 3730k at 4.7 ghz
H100
16gb Corsair Dominator GT RAM at 1866 mhz
2 x Asus GTX DCU2 670's overclocked at 1258 mhz
1 x 1tb Storage Drive
1 x 2 tb Game Drive
1x 60 gb SSD Boot Drive
CoolerMaster HAF X
Kingwin Lazer 1000w
what ram fan is that.. does it conflict with the gfx card in the first slot ?
Rampage IV Extreme
GTX 760
GTX 560ti
Cosmos 2 case
