Asus Rampage Extreme IV - driver - windows base device problem
basweb_de
after reinstalling W10, I have a lot (over 16) base device drivers missing in the device manager, but I can't find any working drivers for this mainboard anywhere. I installed the USB drivers from the ASUS support website, but it didn't help.
Any chance to get old drivers somewhere? It's kinda strange, because in my old W10 installation (migration from 7), it all worked fine.
Now nothing helps, nothing works.
Not sure if the base device drivers missing are bad - but wonder if ASUS is really not supporting old mainboards anymore.
What about the ASUS AI Suite? Yes, I can monitor fans etc. via other programs, but why is all this stuff not working anymore? Is it THAT different to newer mainboards?
Would appreciate some tips, because all I can do now is: Accept the sad truth xD
Cheers,
Bastian
17 REPLIES 17
vennacher
Check sparkyboy's driver pack. This for the R4BE but most all apply to the RIVE. https://rog.asus.com/forum/showthread.php?72562-Windows-10-WHQL-RIVBE-driver-pack&highlight=sparkybo...
MB : Rampage IV BE. - Bios 0801
CPU : i7 3970x @ 4500 MHz, Offset +0.030v, Regular LLC, Fixed Frequency 750, C1E Enabled, C3/C6/C7 Disabled
CPU VCCSA: Manual 1.150v, Regular LLC, Fixed Frequency 500
RAM : Corsair Vengeance @ 1866 MHz - 64GB
Disks : Raid0 2x Intel 520 480GB; 2x Seagate 2TB
GFX : EVGA GTX690
Audio : Creative X-FI Titanium HD
PSU : Corsair AX1200i
Optic BD\DVD : Lite-On Blu-Ray; Samsung DVDRW
Cooler\Case : Corsair H100i v2 2; Silverstone TJ07
OS : Win10 Pro 64
Hey vennacher,
thanks a lot, that's working, no unknown base devices anymore.
Cheers!
MoKiChU
Level 40
You need these firmware/drivers for your ASUS ROG Maximus IV Extreme/Black Edition motherboards :
[FIRMWARE] Intel ME (B75/Z75/H77/Z77/X79)
[DRIVERS] Intel Chipset/MEI/SATA (6x/7x/8x/9x)
- Intel Chipset Drivers
- Intel MEI Drivers (Drivers Only) :
Drivers - 6x/7x
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
Drivers - 6x/7x
[DRIVERS] ASMedia SATA/USB
- ASMedia SATA AHCI-RAID (Drivers Only)
- ASMedia USB Drivers (Drivers Only) :
Drivers - ASM1xxx
[DRIVERS] Intel Ethernet/WiFi/Bluetooth
- Intel Ethernet Drivers (Drivers Only) :
Drivers - 82579
[DRIVERS] Broadcom WiFi/Bluetooth
- Broadcom WiFi Drivers (Drivers Only)
- Broadcom Bluetooth Drivers (Drivers Only)
[DRIVERS] Realtek Audio (Intel 6x/7x/8x/9x/1xx & AMD Legacy 6xx/7xx/8xx/9xx)
You have an ASUS ROG Realtek motherboard, so :
You need Realtek High Definition Audio Drivers (HDA - ASUS ROG/TUF/PRIME DTS&RTK) from the first post of the thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
MoKiChU
Level 40
You need these firmware/drivers for your ASUS ROG Rampage IV Extreme motherboard :
Drivers - 6x/7x
Drivers - 6x/7x
Drivers - 82579
[DRIVERS] Qualcomm WiFi/Bluetooth
- Qualcomm Bluetooth Drivers (Drivers Only) :
Drivers - QCAxxxx
You need these firmware/drivers for your ASUS ROG Rampage IV Black Edition motherboard :
Drivers - 6x/7x
Drivers - 6x/7x
Drivers - 82579
Hi MoKiChU,
thx, but it's already working with the driver pack vennacher linked.
Not sure if the Maximus board is the same (driver wise) as the Rampage?
Cheers!
basweb.de wrote:
Hi MoKiChU,
Cheers!
It was a typo, it's now fixed.
Hi MoKiChU,
thanks, gonna try the newer pack then.
Cheers!
MoKiChU
Level 40
basweb.de wrote:
Hi MoKiChU,
They are more recent than the drivers contained in the drivers pack previously linked by vennacher (and your BT drivers are not included in this pack).
Cheers!
