Asus Prime Pro 370 Led not working
Tavsalli
I have bios reset the motherboard several times because of the memory problem. (Dram does not work at 2933 MHz, Memory is running at 2666 MHz.) The speed issue is not very important right now. The motherboard's lights are not working. I checked the bios. It looks right. I installed the software 2-3 times again. I ran the settings, the problem was not resolved.
Asus prime pro x370
Corsair Vengeance ddr 4 2*16 3000 mhz
Amd 1800x
0 REPLIES 0
