Asus Maximus VI Formula Z87 - CPU Opt fan and CPU fan
LucikMucik
Hello, I have question about CPU Opt connector. Is it mirrored from CPU Fan connector? (When I set speed in AISuite will be the same speed on CPU Opt?)
I have 8 fans (2x 480mm radiator), I want to split to both connectors.
Chino
Level 15
Good! Thank you.
desolator4u
I have to ask.
I have a CPU cooler using a 4 pin PWM FAN in CPU header 1
I have a 3 pin fan i want to use in CPU header 2. Will there be a problem? Both fans are different speed, one is 3 pin and one is 4 pin.
I am worried that since 3 pin fan speeds are controlled by voltage and 4 pin fan speeds are controlled by RPM. I don't want anything to be damaged. Same M VI Formula
8700K / Noctua U12S / Maximus X Hero / 2x8GB Corsair Vengeance 3200MHz / EVGA GTX 1080 Ti / Seasonic Prime 650W / 4 x 1TB SSD / 970 Pro 512GB M.2 / Game Zero Headset / K95 Platinum / Logitech G502 / Win 10 x64/ ViewSonic XG2701 1080p 144Hz
