ASUS Maximus VI Formula 3 pin fan control question.
Retired
Not applicable
So I'm planning on doing some water cooling with my computer and I want to use some Gentle Typhoon AP-15 fans for the radiators. The only problem is that the fans are 3 pin. Am I able to get 3-pin fan control when using a 3-pin splitter when I plug all the fans into it. Plugging the Splitter into the CPU_Fan.
Thanks.
jab383
The fan controls are limited to 1 amp. The splitter would work if the fans draw less than 0.5 amps each.
You could also try one fan in the CPU_Opt or one of the chassis fan controllers. Those controls are also based on CPU temperature.
Jeff
