ASUS Maximus IV Extreme-Z USB 3,0 Problems Agian! FIX IT
Hydx
Hello so i got this usb 3,0 Problem agian. and now i get two Unkown Device before it's just one. i have follow every singel guide here on this forum uppdated the drivers and lastest bios. I have i7 2600 k with cooler master HAF X. only 2 usb ports work fine on the back 5 is not working anymore. also tried to change it to Nec settings in bios and changed it back to normal still the same problem. Why waste 350 § USD on a motherboard that is not complette? any tips or should i send it back?
[IMG][/IMG]
4 REPLIES 4
HiVizMan
Level 40
Not sure I like being shouted at to be honest. You did know that capital letters is shouting yes? So shouting at me to "FIX IT" does not really make me want to help you at all.
Contact your regional RMA office for assistance.
Hydx
It wasent toward to you to fix it but was meant to asus >< well however seems like there is a issue with my case opend up the case pulled a bit on my motherboard now everything is oki agian >< seems like i need to get a new better case! Sry for Shoating
Myk_SilentShado
Level 15
Sounds to me like it's not your case at all, rather a matter of you not connecting things properly. you proved that point with "Opened up the case, pulled a bit on my motherboard, now everything is okay again" When things go awry, the first thing you should always remember to do and this is just a friendly piece of advice....make sure you check all connections everywhere, wires, cables, plugs, etc etc etc and then go through your hardware and so on...of course this is totally dependent on the nature of any problem at any given time. 🙂
HiVizMan
Level 40
All good my friend and remember we are all trying to help each other here. We do this because we want to help, not because we work for ASUS. Most of the folk here are just like you and me, the guys with the names@ASUS they work for ASUS.
Guess it is ok to shout at them 😄 Just joking and thank you for taking the time to respond.
Cheers
