Asus Maximus IV Extreme - Bios 3604x64 - Wake On Lan Problem
sinanakyazici
I have updated mainboad bios to 3604. I would like to use feature of wake on lan. However I cannot find this feature on my bios. There are Power by ps2/keyboard, power by ps2/mouse, power by pcie, power by rtm and euc ready but not power by wake on lan.
What should I do ?
King Regards...
Praz
The board should wake on LAN by default. What type of network and operating system are using?
I am using a locak network for home and windows 8.1.
I would like to wake my computer from android. I installed pcautowaker. I have tried to wake my computer by using that application. But It didn't work. I have set ethernet card property as 'Allow this device to wake the computer' and 'Only allow a magic packet to wake the computer'.
I use hibernate but It doesnt wake. I have tried to plug and unplug ethernet cable. Nothing has changed.
I don't know what can I do more else ?
Praz
Disable Fast Start in Win8.1. With Fast Start enabled all devices are placed in the D3 state which does not allow waking on LAN. If the system still will not wake from sleep you will need to trace the packet to see if it is actually getting to the computer. Not all routers will properly pass a magic packet.
