Asus maximus 7 formula no post no beep error 15?? Help
stemz05
Ive been having an issue with this board where it wont boot or post. Its gets stuck on error 15 ive also noticed that the cpu led is on. If i keep hitting the reset button it will eventually boot but once i restart it will do the same thing. Ive tested the ram and the hard drives but ive had no luck. Any ideas? My specs are asus maximus 7 formula, i7 4790k, 16 gb corsair , 2 gtx 760 in sli, evga 1000 watt psu, samsung evo 840 250 gb ssd. And a samsung 1tb hhd.
60 REPLIES 60
Nate152
All right, that's sounding better.
I wonder if the waterblock was somehow shorting the board or maybe it was too tight?
stemz05
Idk thats a little funkey i was thinking the same thing. The issue started after i grinded down the mounting posts
Nate152
Well this is good news, it sounds like you've found the problem and have a 100% working motherboard now.
But again a little testing and time will tell. 😉
stemz05
It gave me the error code like 3 times after i mounted it on to the case but i reflashed bios and it booted into windows now
Nate152
All right
Let's hope you found the problem and a bios reflash is all you needed.
I got my fingers crossed this time. 🙂
stemz05
2 gpus installed all ram installed and its booting fine...i think that was the problem lol seems to be running just fine
Nate152
I think you can put on your ROG party hat now and do a little dance. 😉
Great job finding the problem stemz05 !
stemz05
so after all that idk it seems like the rog armor is causing a short on the case...idk im driving my self crazy. i get an error 15 and an error 94 now. it will bot a little more frequent now but i have to keep hitting reset...
stemz05
it gets stuck on error 62 aswell when i gets to that code it post then the screen goes black there a _ at the top left hand corner of the screen then it freezes
stemz05
the reason i think its a short is cuz when i jiggle the board the error codes change i was hopeing i was imagining it but i dont think i am...
