Another dude with realtek audio issue
Elcapitanpdx
prime x570-pro board. I just want to use the integrated audio jack but there is no option to select this as an output. There also is no audio input available.
win11 pro clean install a couple months ago, currently on version 10.0.26100
Device Manager shows only hdmi HD audio options and the FX Sound application I downloaded hoping it might work. This is under both Audio i/o and Sound controllers. Audio does work using the HDMI.
Realtek does not appear anywhere in the 'services' list.
I've tried installing audio drivers downloaded via Asus drivers page. No issue running the installers. I've tried all of the .exe's and setup multiple times. They run to completion but there is no change in devices.
Nothing showing as needing an update in Armory Crate.
HD Audio is currently enabled in BIOS but I have tried disabling that as well.
I tried running the AMD cleanup utility as well, that did nothing to help.
Hoping someone can tell me wtf I'm missing cause this is a maddening first experience with Asus.
Elcapitanpdx
I have also tried manually forcing the driver add by running the installer and then pushing it in device manager. However the summary at the end shows that 0 of 1 drivers were installed for everything.
