AiCharger problem on CFV ?
klosz007
Hello,
I recently bought and installed front USB 3.0 panel in my PC, the one that utilizes 20-pin connector on Crosshair V. I enabled AI Charger+ in AI Suite but it does not seem to work as I expected fully.
When I connect my iPhone 4 to USB 3.0 when the PC is on, iPhone is being recharged, even if I put my PC into standby (S3/STR) next.
However, if I connect iPhone to my PC when the PC is already in standby, the phone does not recharge at all - I have to resume the PC from standby first for charging to start, then I can put the PC back into sleep and charging will continue in standby.
Is this normal behavior ?
I am using Win7 x64 home premium on CH V (UEFI 0705), AI Suite 1.01.40 (AI Charger+ 1.00.06), ASMedia USB 3.0 drivers 1.12.5.0 (the latest ones I was able to find).
Best regards,
Zbyniu
Praz
Yes that is how the charging is designed to work. Whatever you are going to charge needs to be connected before the system is put to sleep.
