Ai suite fan xpert 2 not working?
Teletha
why can'tAI suite read chassi fan 3 and why can't i control OPT_fan 1-2 i want the auto-fan stop there too.
https://i.gyazo.com/8fa6e96d9c571dd87a247083cf6449bc.png
AMD Ryzen 7950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX TUF 4090 OC@3GHz [EKWB Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | 980+950 Pro 1TB M.2 | x6 850 PRO 512GB | NAS 4x 18TB Seagate Exo Raid 10+Backblaze | Lian-Li o11D XL | Main Screen: Samsung NEO G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | Copyright©1996-2023 Teletha™ All rights reserved. ® -"Lightning. It flashes bright, then fades away. It can't protect. It only destroys."
Nate152
Hello Teletha
Have you run the fan tuning utility in ai suite? You will need to do this for it to recognize your fans, if I'm not mistaking cpu_opt 1 and 2 is controlled with the cpu fan header and all three fans will run at the same speed as the cpu fan.
Nate152 wrote:
Hello Teletha
ye i did the fan tuning. isn't only opt_cpu the one that is linked with the cpu fan? cause the other opt_fan are not near the cpu fan header
Nate152
Well my board has the cpu and cpu_opt 1 and 2 headers too and are close to each other. I haven't officially tested them but I'm almost certain they will run at the speed of the cpu fan.
Are you able to see and control your fans in the bios?
