Ai Suite 2 Problem
marm0ta
Can someone tell me why when i go in High Perfomance mode, AI Suite 2 give's me these warning popup. It does only when i;m in high performance. And also it says that OPT fan 2 and 3 are on 0 rpm, how the hell ? I don't have any fan coonected on these two.
I also had the same problem but on chassis fans 1 , 2 and 3 but i dont know what i did, but now chassis fan are not showing that warning popups again only that OPT fan 1.
These problems started i think 2 or 3 weeks ago.
Screenshot:
http://img215.imageshack.us/img215/1295/32043127.png
Second screenshot with my second problem.
http://img545.imageshack.us/img545/246/1243.png
10 REPLIES 10
Retired
Not applicable
If u dont use opt_fan at all, you can simply disable it in bios..
If i remember correct..
The warings (in pic 2) is becouse the limit settings (in probe II)..
You dont have any fans on those sockets?
Im kinda split about this.. Due to your pop up in the right corner
The warings is becouse the go under the limit settings (in probe II)..
On OPT 2 and 3 i didn't connected any fans.
Retired
Not applicable
AHa, fan on 1
nothing on 2
nothing on 3
Is that the case
Retired
Not applicable
In there you can fool around with opt_fans
Uncheck ALERT
Hate not to be able to upload pics in this forum (please do something)...........
Or use bios... Fan speed "control or settings, cant remember">
What du you have on opt_1?
Uncheck ALERT
On OPT 1 is an 180 mm fan on top of the case.
I already deselected the alert thing. But my question if this is normal to that. Is my motherboard bad ? Do i need to RMA it ? I dont know why it started doing these.
Retired
Not applicable
Nothing important, in other words..
opt_fan1 > duty 50%
opt_fan2> disable
opt_fan3_disable
In bios, im not 100% sure about the exact phrases in there.. I dont think there is something wrong with you pc, just some settings..
Yes i consider a activated socket acting like it should, without anything connected to it..
Retired
Not applicable
Opt_fan isa GREAT tool, if used with therm. sensors....
Retired
Not applicable
And if you still get a balloon pop up on opt_fan 1. Lower the limit in probe 2, or raise the duty % in bios..
Retired
Not applicable
Problem solved???
Curious...
