02-24-2013 12:07 PM - last edited on 03-06-2024 09:58 PM by ROGBot
02-24-2013 03:12 PM
02-25-2013 10:42 AM
as soon as the Intel Matrix Storage Manager Screen appears for a few seconds press Ctrl+I
02-25-2013 01:13 PM
02-25-2013 05:01 PM
02-26-2013 05:05 AM
HiVizMan wrote:
I wonder if your BIOS is keeping your settings when you select RAID as SATA mode? What happens after you press F10 to save and exit the settings? If you go straight back into BIOS do you see RAID as your mode of SATA? And when looking at your devices in BIOS are your hard drives picked up?
Grymmie wrote:
Have you tried BIOS No. 2? Which probably is 0704 or earlier, just to see if its the NVRAM on BIOS 1 that's the problem? Which I think it is. If you find it works on BIOS No. 2, then a CMOS clear (30 minutes without power or battery) to clear the NVRAM on BIOS No.1 and possibly a reflash should resolve the problem.
02-26-2013 05:47 AM
02-26-2013 09:34 AM
