01-31-2013 01:48 AM - last edited on 03-06-2024 10:13 PM by ROGBot
01-31-2013 05:38 AM
01-31-2013 07:42 AM
01-31-2013 05:18 PM
01-31-2013 09:54 PM
Shelha wrote:
Thanks for your reply Chino, but as I stated in my original post, the 6-pin PCIe for the video cards do not fit the 6-pin connector for EZ_PLUG_1 on the motherboard. I tried the connectors from the 2 PSUs I mentioned and non of them work. The ASUS MBD manual shows a picture of the connector layout and after comparing it to the 6-pin PCIe connectors on the PSUs, the connector required for the motherboard has 3 square prongs and 3 notched prongs, the connectors on the PSUs have 2 square prongs and 4 notched prongs. Am I the only person with this issue? I found a couple of reviews on amazon were 2 people got adapters that had the wrong pin configuration, but there is no way to know which adapter has the correct pin layout. This is so frustrating, hopefully somebody can help!
02-02-2013 03:57 AM
Chino wrote:
My bad. I've never examined that slot closely enough to notice that the pin layout was different. But despite the difference in the pins, the connector on the MVE is still indeed a PCIe 6 pin cable. Maybe not a lot of people know or notice it but the 6 pin PCIe cables that come with modern PSU is actually the second version. Some older and some modern PSU still come with the first version 6 pin PCIe cables.
Maybe it was a design slip up on Asus's part to incorporate the previous pin layout onto the board when most modern PSUs don't come with thoss PCIe cables anymore. So the solution would be to either find an adapter like you mentioned or get a PSU that still comes with the version 1 cables.
On a sidenote, why don't you try to run the Quad Sli configuration without it meanwhile? Unless you'll be overclocking the crap out of them, I don't think there's an inmediate use for the extra power.
01-31-2013 05:45 PM
01-31-2013 07:13 PM
Area 66 wrote:
DO you really need it, what kind of GPU are you using on that board ?
02-02-2013 04:04 AM
Area 66 wrote:
with 4 GPU it's a Rampage Extreme and a i7-3930k 6 cores you need
